An excerpt of the generated "eplusout.err" file (when running the IDF with either EPW files):
** Severe ** GroundHeatTransfer:* objects found [...] not supported directly by EnergyPlus.
** ~~~ ** You must run the ExpandObjects program on this input.
As mentioned elsewhere (e.g. here and here), you need to first run the Basement preprocessor program.
Failed to launch altogether, not halfway through. An excerpt of the generated "eplusout.err" file (when running the IDF with either EPW files):file):
As mentioned elsewhere (e.g. here and here), you need to first run the Basement preprocessor program. program.
Failed to launch altogether, not halfway through. An excerpt of the generated "eplusout.err" file (when running the IDF with either EPW file):
