I improved @DavidGoldwasser's original Set Window to Wall Ratio by Facade measure to Add Remove Or Replace Windows which can be run using the Apply Measure Now feature in the OS app.
I improved @DavidGoldwasser's @David Goldwasser's original Set Window to Wall Ratio by Facade measure to Add Remove Or Replace Windows which can be run using the Apply Measure Now feature in the OS app.
I improved @David Goldwasser's original Set Window to Wall Ratio by Facade measure to instead Add Remove Or Replace Windows which can be run using the Apply Measure Now feature in the OS app.
| 4 | No.4 Revision |
I improved @David Goldwasser's original Set Window to Wall Ratio by Facade measure to instead Add Remove Or Replace Windows which can be run using the Apply Measure Now feature in the OS app. Let me know if you find any bugs.
| 5 | No.5 Revision |
I improved @David Goldwasser's original Set Window to Wall Ratio by Facade measure to instead Add Remove Or Replace Windows which can be run using the Apply Measure Now feature in the OS app. Let me know if If you find any bugs.bugs please submit an issue to my GitHub repository.
| 6 | No.6 Revision |
I improved @David Goldwasser's original Set Window to Wall Ratio by Facade measure to instead Add Remove Or Replace Windows which can be run using the Apply Measure Now feature in the OS app. If you find any bugs please submit an issue to my GitHub repository.
