You need an OpenStudio Workflow (OSW) to run a model from command line. Using the OpenStudioApplication is the simplest to create one with measures etc (if your model is at /path/to/mymodel.osm, then at /path/to/mymodel/in.osw you have the workflow file).
The simplest one would look like this:
"weather_file": "myweatherfile.epw",
"seed_file": "mymodel.osm",
