I have not run your model (since I do not have Matlab installed) but looking at your variables.cfg
I see the following
<BCVTB-variables><!--INPUT--><variable source="Ptolemy">
<EnergyPlus schedule="OtherEqTest"/>
</variable>
This indicates that EnergyPlus will receive values from outside (in your case from Matlab) that will be fed into an EnergyPlus schedule. However, when I look at your IDF I see the following:
ExternalInterface:Actuator,
OtherEqTest, !- Name
OthEq, !- Actuated Component Unique Name
Other Equipment, !- Actuated Component Type
Design Level; !- Actuated Component Control Type
where OtherEqTest is defined as an Actuator as opposed to a Schedule.
This mismatch is most likely causing your system not to run properly.
