If you leave it as an EPW file, the weather converter assumes that everything is okay. It will convert some things, such as dew point or relative humidity if those values are "missing" but not, I think, the solar values.
You will need to input it as a "custom" with a "definitions" file to get it to effect a split in solar. I would attach it here but the unmet hours will only apparently allow picture files. I will try to send it as a private message.
Linda
FIBPSA, FASHRAE https://climate.onebuilding.org - free repository of climate data for building simulation Climate.onebuilding is a FREE service not supported by any outside organization or government agency.
Can't send private messages -- here it a dropbox link to the standard EPW format https://www.dropbox.com/s/959stzgl009ea3o/StdEPWDefFormat.def?dl=0
Linda
Can't send private messages -- here it a dropbox is a link to the standard StdEPWDefFormat.def and here is the content:
&wthdata
NumInHour=1
InputFileType='CUSTOM'
InFormat='DELIMITED'
DataElements=year,month,day,hour,minute,datasource,Dry_Bulb_Temperature,Dew_Point_Temperature,Relative_Humidity,Atmospheric_Pressure,Extraterrestrial_Horizontal_Radiation,Extraterrestrial_Direct_Normal_Radiation,Horizontal_Infrared_Radiation_Intensity_from_Sky,Global_Horizontal_Radiation,Direct_Normal_Radiation,Diffuse_Horizontal_Radiation,Global_Horizontal_Illuminance,Direct_Normal_Illuminance,Diffuse_Horizontal_Illuminance,Zenith_Luminance,Wind_Direction,Wind_Speed,Total_Sky_Cover,Opaque_Sky_Cover,Visibility,Ceiling_Height,Present_Weather_Observation,Present_Weather_Codes,Precipitable_Water,Aerosol_Optical_Depth,Snow_Depth,Days_Since_Last_Snow,Albedo,Liquid_Precipitation_Depth,Liquid_Precipitation_Quantity
DataMissingValues=99999,99,99,99,99,,999,999,999,999999,9999,9999,9999,9999,9999,9999,999900,999900,999900,9999,999,999,99,99,9999,99999,9,999999999,999,0.999,999,99,999,999,99
DataUnits='x','x','x','x','x','x','C','C','%','Pa','Wh/m2','Wh/m2','Wh/m2','Wh/m2','Wh/m2','Wh/m2','lux','lux','lux','Cd/m2','deg','m/s','tenths','tenths','km','m','x','x','mm','{.001}','cm','x','{.01}','mm','hr'
DataConversionFactors=1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1
DelimiterChar=','
&miscdata
Comments1='Standard EPW format https://www.dropbox.com/s/959stzgl009ea3o/StdEPWDefFormat.def?dl=0Custom def format'
SourceData='EPW'
&datacontrol
NumRecordsToSkip=8
MaxNumRecordsToRead=8784
MissingWindDirAction=RANDOM
! Other options on datacontrol:
! MissingDataAction
! MissingWindDirAction
! MissingWindDirValue
! MissingOpaqueSkyCoverAction
! MissingOpaqueSkyCoverValue
! MaxWindSpeed
! MaxDirectSolar
! MaxDiffuseSolar
! MaxIlluminanceValue
! GenerateSolarRadiationWarnings
! GenerateIlluminanceWarnings
! MinDBTempByMonth
! MaxDBTempByMonth
! MinDPTempByMonth
! MaxDPTempByMonth
Linda
| 4 | No.4 Revision |
Can't send private messages -- here Here is a link to the StdEPWDefFormat.def StdEPWDefFormat.def and here is the content:
&wthdata
NumInHour=1
DelimiterChar=','
&miscdata
Comments1='Standard EPW Custom def format'
SourceData='EPW'
&datacontrol
NumRecordsToSkip=8
! MissingDataAction
! MaxWindSpeed
! MaxDirectSolar
! MaxDiffuseSolar
! MinDBTempByMonth
! MaxDBTempByMonth
! MinDPTempByMonth
! MaxDPTempByMonth
Linda
