![]() | 1 | initial version | |
Hi Ashok. I'd suggest using the weather data tool Elements. This tool will let you display all of your weather file data in tabular form. You can easily make edits by copy/pasting data from other sources. You can also make quick charts or export to several different weather file formats including .epw or .bin
http://bigladdersoftware.com/projects/elements/
