1 | initial version |
During a simulation OS uses the Temp directory to read and write files. The contents of <OsmFolder>/run/
is copied to the Temp directory and then deleted after the new files are written and the simulation is completed. On Windows machines OS uses the C:\Users\<UserName>\AppData\Local\Temp\OpenStudio.xxxxxx\resources\run\
path.
The issue I had was in referencing the OSM directory structure rather than the Temp directory. So to have a measure write files during a simulation and have them appear in the OSM folder I had to make sure any paths used in the measure were relative to the measure file. The File.expand_path("../../../", __FILE__)
worked well for moving around the Temp OSM directory.
2 | No.2 Revision |
is copied to the Temp directory and then deleted after the new files are written and the simulation is completed. On Windows machines OS uses the path:
path.
