Is it a large zone? Often two small units are used in larger zones. You can have more than one ZoneHVAC equipment in each zone. I've never used two of the same type, but I don't see why you couldn't. Also, you can connect more than one indoor unit to one outdoor unit using the ZoneTerminalUnitList.
