You could a deadband, which could be something like:
If (Num_People > 0) && (Sensor_CO2 >=800 + deadband/2),
SET Window = 1,
ELSIF (Sensor_CO2 <= 800 - deadband/2),
SET Window = 0,
ENDIF
If IF (Num_People > 0) && (Sensor_CO2 >=800 + deadband/2),
SET Window = 1,
SET Window = 0,
ENDIF
You could a deadband, deadband, which could be something like:
SET Window = 1,
SET Window = 0,
ENDIF
| 4 | No.4 Revision |
SET Window = 1,
SET Window = 0,
ENDIF
Or you could use trend variables and add hysteresis.
| 5 | No.5 Revision |
You could add a deadband, to the program, which could be something like:
SET Window = 1,
SET Window = 0,
ENDIF
