The BCVTB version 1.5.0 was tested with EnergyPlus 8.2.0. This was the latest version which was available at the time of the BCVTB release. I just tried to run the examples which come along with the BCVTB version 1.5 with EnergyPlus 8.3.0 and they all work. You should I believe be fine using the BCVTB with EnergyPlus version 8.3.0.
