@Thomras which version of CBECC 22 are you using? The website has installers available for 2022.2.0 as well as 2022.2.1.
I had installed 2022.1.0, and can confirm that when I click on the Help / Quick Start Guide and Help / User Manual menu, I get a "file not found" error (see below).
However, these files should definitely be on your computer if the installer worked correctly. I found them in C:\Program Files (x86)\CBECC 2022 (see below).
@Thomras which version of CBECC 22 are you using? The website website has installers available for 2022.2.0 as well as 2022.2.1.
