If you want to see the electricity/natural gas consumption for the heating, cooling and fan systems, you can check the output html table after running the simulation on EnergyPlus. If you want to know the amount of heating or cooling provided by these coils, you can use the output variables Heating Coil Heating Rate (or Heating Coil Heating Energy), Cooling Coil Total Cooling Rate (or Cooling Coil Total Cooling Energy).
