It doesn't seem like there are any components of that type published on the BCL. You might find some relevant data in the OpenStudio Application Resource files installed at "C:\openstudioapplication-1.5.0\Resources". You might also be able to use one of the OpenStudio Model Articulation Measures to generate a code baseline building and use that as a source for constructions.
