1 | initial version |
Assuming that you use air to reject heat and that you do not have a cascade system (CO2-R134a), CO2 has a low critical point therefore requires a gascooler instead of a typical condenser. Moreover, you require a TranscriticalSystem object to model these systems. There is not a gas cooler object in openstudio application nor a transcritical system so you need to either insert them via a measure or manually by modifying the txt.
