Defining parameters in jEPlus is covered in Chapter 4 of the User's Manual. How to define probabilistic distribution of the parameter values is described in 4.3 in particular: http://www.jeplus.org/wiki/doku.php?id=docs:manual_1_5_params#sample_syntax
Defining parameters in jEPlus is covered in Chapter 4 of the User's Manual. How to define probabilistic distribution of the parameter values is described in 4.3 in particular: http://www.jeplus.org/wiki/doku.php?id=docs:manual_1_5_params#sample_syntaxhttp://goo.gl/a4XdhI
