The North Axis rotates the building counter clockwise, so a (+) value rotates the building to the left and a (-) value will rotate it to the right according to the right hand rule. By default the north axis is set to 0 and is indicated by the green line in SketchUp. Try setting the field to a non-zero number and an orange axis should appear indicating the new north axis.
