Finally, I was able to build the latest openstudio-standards using Ruby version 2.7.2p137 (2020-10-01 revision 5445e04352). Below are summary of the exercises I went through in resolving the build issue I had:
I had two versions of Ruby DevKits (devkit-2.5.8 and devkit-2.7.2). I uninstalled and installed both ruby versions and tested it with bundler versions (2.1.0 and 2.1.4) and their dependencies, but it did not resolve my problem.
Then I uninstalled both ruby versions and installed Ruby version 2.5.8 only and tested with bundler versions 2.1.0 and 2.1.4. This configuration also failed to build. Note that I tried this configuration because the openstudio-standard suggests using ruby version 2.5.8 at the link here developmentInformation.
Finally, I uninstalled Ruby version 2.5.8, installed Ruby version 2.7.2p137 and bundler version 2.1.4, and it worked. Now, only Ruby version 2.7.2p137 resides in my computer.
I have two questions for openstudio-standards developers to comments on:
Thanks.
