Hi @Amirhossein and @Aaron Borian Thanks for this post. I am trying to test thermochromic paints with only two options (darker and lighter color), under 28 dergres and over 28 degrees. I followed @Aaron Borian script, but there is a sever error running the simulation.
Do you know how can I fix it?
This is the script that I am using:
<forallexternalsurfaces> EnergyManagementSystem:Sensor, Surface_Outside_Face_Temperature_<loopsurfacevariablename>, <loopsurfaceidfname>, Surface Outside Face Temperature; <loopnextsurface>
<forallexternalsurfaces> EnergyManagementSystem:Actuator, Surface_Cons_State_<loopsurfacevariablename>, <loopsurfaceidfname>, Surface, Construction State; <loopnextsurface>
EnergyManagementSystem:ConstructionIndexVariable, EMS_Cons_High_Abs, !- Name High Absorptance Construction; !- Material, 3_1_10061
EnergyManagementSystem:ConstructionIndexVariable, EMS_Cons_Low_Abs, !- Name Low Absorptance Construction; !- Material, 19_1_10062
EnergyManagementSystem:ProgramCallingManager, Thermo, BeginTimestepBeforePredictor, Thermo;
EnergyManagementSystem:Program, Thermo, <forallexternalsurfaces> if Surface_Outside_Face_Temperature_<loopsurfacevariablename> < 28, set Surface_Cons_State_<loopsurfacevariablename> = Material, 3_1_10061 elseif Surface_Outside_Face_Temperature_<loopsurfacevariablename> > 28, set Surface_Cons_State_<loopsurfacevariablename> = Material, 19_1_10062, endif, <loopnextsurface> ;
And this is the error message:
* Severe * GetRuntimeLanguageUserInput: EnergyManagementSystem:ConstructionIndexVariable="EMS_CONS_HIGH_ABS invalid field. * ~~~ * Invalid Construction Object Name=HIGH ABSORPTANCE CONSTRUCTION * ~~~ * Construction was not found. * Severe * GetRuntimeLanguageUserInput: EnergyManagementSystem:ConstructionIndexVariable="EMS_CONS_LOW_ABS invalid field. * ~~~ * Invalid Construction Object Name=LOW ABSORPTANCE CONSTRUCTION * ~~~ * Construction was not found. * Fatal * Errors found in getting EMS Runtime Language input. Preceding condition causes termination.
Thanks! Camila
<ForAllExternalSurfaces>
** Severe Thanks! Camila
