If you're just starting a model from scratch and not using an existing (legacy) EnergyPlus model, you're probably better off using OpenStudio rather than the Legacy PlugIn. I recommend following the tutorial materials here. Those materials along with the available YouTube videos will walk you through the entire process - including how to use pre-defined construction materials.
