You need to specify the design level of the OtherEquipment object too. If you look at the .err file, you'll see this warning:
** Warning ** GetInternalHeatGains: OtherEquipment="PRODUCT", specifies Design Level, but that field is blank. 0 Other Equipment will result.
The most common way of describing a piece of equipment is setting Design Level Calculation Method as "EquipmentLevel", DesignLevel as the maximum power usage of the equipment, and providing a schedule with fractional values (with a maximum of 1).
In your case, your schedule values appear to already be in units of Watts (?), so you could specify the DesignLevel as 1.
