Here's another way to solve it: If you select "DisplayExtraWarnings" from the "Output:Diagnostics" object, you should see some warnings similar to this:
* Warning * GetVertices: Distance between two vertices < .01, possibly coincident. for Surface=C1000000_C24, in Zone=FC-1-1 * ~~~ * Vertex [3]=(98.38,70.59,3.05) * ~~~
* Vertex [2]=(98.38,70.60,3.05) * ~~~ * Cannot Drop Vertex [3]; Number of Surface Sides at minimum. This surface is now a degenerate surface.
Further down you will see your severe error that just counts up the number of degenerate surfaces:
* Severe * GetSurfaceData: There are 12 degenerate surfaces; Degenerate surfaces are those with number of sides < 3. * ~~~ * These surfaces should be deleted.
It's not necessarily surfaces that have <3 sides initially. All of these surfaces had 4 points initially. Hope this helps.
DistanceDistance between two vertices < .01,possiblypossibly coincident. forSurface=C1000000_C24,Surface=C1000000_C24, in Zone=FC-1-1* ~~~ * Vertex
* ~~~ * Vertex [3]=(98.38,70.59,3.05)* ~~~
* ~~~ * Vertex [2]=(98.38,70.60,3.05)
* ~~~ * Cannot Drop Vertex[3];[3]; Number of Surface Sides atminimum.minimum. This surface is now a degenerate surface.
DegenerateDegenerate surfaces are those with number of sides < 3.* ~~~ * These
It's not necessarily surfaces that have <3 sides initially. All of these surfaces had 4 points initially, and when combing through the model, also show up with 4 sides.
| 4 | No.4 Revision |
Further down you will see your severe error that just counts up the number of degenerate surfaces:surfaces. This is the only error you would see if you didn't use Output:Diagnostics, DisplayExtraWarnings:
| 5 | No.5 Revision |
Further down you will see your severe error that just counts up the number of degenerate surfaces. This is the only error you would see if you didn't use Output:Diagnostics, DisplayExtraWarnings:
