You need to add a heat recovery object on your AHU. Your AHU should have the following components, Heat recovery, Outdoor air mixer, Outdoor air controller, Fan, possibly heating coil switched to off. You will also need an outdoor air equipment list, and an outdoor air system component. The heat exchanger needs to go first before the OA mixer. If you expand any of the templates they will have the OA stuff all set out and you just need to add the heat exchanger in.
