Here is the solution for my question above, which I figured out with Dr. Georg Reichard in Virginia Tech. So to change the thermostat setting in OS, we need to go to the Schedule tab change the upper and lower limits for cooling and heating set up.
Here is the solution for my question above, which I figured out with Dr. Georg Reichard Reichard's help in Virginia Tech.
