@Mel - here's the code for an EnergyPlus measure that will do what you need. It creates the OutputControl:Table:Style object that allows you to select additional output files and change the units to IP.
I had to give the file a fake extension to post it here, but it should be renamed measure.rb after you download it. Follow these steps to create your own copy of the measure:
Note: using this measure will prevent OpenStudio from displaying the end use bar graph and data after a simulation. From the Results Summary tab select EnergyPlus Results from the Reports menu which should allow you to view the eplustbl.htm file in IP units from within your OSM.
Note: using this measure will prevent prevent OpenStudio from displaying the end use bar graph and data after a simulation. From the Results Summary tab select EnergyPlus Results from the Reports menu which should allow you to view the eplustbl.htm file in IP units from within your OSM.
| 4 | No.4 Revision |
@Mel - here's the code See the link below for an EnergyPlus measure that will do what you need. Measure I wrote to change the output format and units. It creates the OutputControl:Table:Style object that allows you one to select additional output files and change the units to IP.
C:\fakepath\measure.jpgthe fields for the OutputControl:Table:Style object.
Change Output Format And Units Measure
measure.rb After a simulation the results in IP units will be available from Results Summary > Reports > EnergyPlus Results. The output files in IP units will be available from osm directory > run > EnergyPlus-0.
Note: using Using this measure will prevent OpenStudio from displaying the end use bar graph and data after a simulation. From the Results Summary tab select EnergyPlus Results from the Reports menu which should allow you to view the eplustbl.htm file in IP units from within your OSM.
| 5 | No.5 Revision |
See the link below for an EnergyPlus Measure I wrote to change the output format and units. It allows one to select the fields for the OutputControl:Table:Style object.
measure.rbAfter a simulation the results in IP units will be available from Results Summary > Reports > EnergyPlus Results. The output files in IP units will be available from osm directory > run > EnergyPlus-0.
Note: Using this measure will prevent OpenStudio from displaying the end use bar graph and data after a simulation (Issue #283).
| 6 | No.6 Revision |
Change Output Format File Formats And Units Measure
| 7 | No.7 Revision |
Change Output File Formats And Units Measure
| 8 | No.8 Revision |
See the link below for an EnergyPlus Measure I wrote to change the output format and units. It allows one to select the fields for the OutputControl:Table:Style OutputControl:Table:Style object.
| 9 | No.9 Revision |
See the link and steps below for to create an EnergyPlus Measure I wrote that will allow you to change the output format and units. It allows one to select the fields for the file formats and units.OutputControl:Table:Style object.
measure.rbThe measure allows the user to select options for output file formats and unit conversions for the EnergyPlus object OutputControl:Table:Style.
| 10 | No.10 Revision |
See the link and steps below to create an EnergyPlus Measure that will allow you to change the output file formats and units.
| 11 | No.11 Revision |
Note: Using this measure will prevent OpenStudio from displaying the end use bar graph and data after a simulation built-in IP reporting measure (Issue #283).
