There are two ways to solve this warning:
_2.
If you go to the loads tab and select one of the people definitions, you will notice that there is some text: Add/Remove Extensible Groups with a small plus and a small minus icon to the right. If you click on the plus icon you add the ability to select a comfort model to be analyzed for that people load to be utilized somehow in the reporting.
