In the PlantLoop object is an input for Load Distribution Scheme. Choices are
PlantLoop,
SequentialLoad; !- Load Distribution Scheme
Choices are:
A14, \field Load Distribution Scheme
\type choice
\key Optimal
\key SequentialLoad
\key UniformLoad
\key UniformPLR
\key SequentialUniformPLR
\default SequentialLoad
This input is set up to allow a set of chillers (2 or more) to run the first few chillers at optimum part load ratio while the last chiller meets the remaining load. I have not tested this but it is supposed to work this way. I'm not sure what happens with only 1 chiller.
In the PlantLoop object is an input for Load Distribution Scheme. Choices are Scheme.
PlantLoop,
SequentialLoad; Optimal; !- Load Distribution Scheme
Choices are:
\type choice
\key Optimal
\key SequentialLoad
\key UniformLoad
\key UniformPLR
