When you assign a weather file to a model on the site tab it uses the lat and long from the EPW for the OpenStudio Site object's lat and long fields. If for some reason you want to use values different from want is in the weather file you could set those with a measure. The selected code in this link shows this being done in the Change Building Location measure.
