Yes, you can specific variable names for data visualization. Here is a screenshot of the measure in an analysis workflow. On the right side of the screen you can see the inputs that Dan has exposed in the measure.
Yes, you can specific specify variable names for data visualization. Here is a screenshot of the measure in an analysis workflow. On the right side of the screen you can see the inputs that Dan has exposed in the measure.
