Hi Jonathan,
the simulation is controlled by the SimulationControl section as well.
SimulationControl,
Yes, !- Do Zone Sizing Calculation
Yes, !- Do System Sizing Calculation
No, !- Do Plant Sizing Calculation
Yes, !- Run Simulation for Sizing Periods
Yes, !- Run Simulation for Weather File Run Periods
No, !- Do HVAC Sizing Simulation for Sizing Periods
1; !- Maximum Number of HVAC Sizing Simulation Passes
There can be also multiple RunPeriods defined in the IDF file. Please check it.
We are using the PythonPlugin mode, specifying the run period start stop by regex changes of source idf file (before execution). It works. I am not much familiar with the Python library mode you are using.
