The number of nodes that are reported for each construction depends on the thermal diffusivity of the materials (α) used in the same and I assume not all of your constructions will be the same. If you read out the variables with higher node numbers for all surfaces (please note that I refer to model planes as "surfaces" here, and not the surface of a construction itself), you will see which ones are divided into more elements.
