@Alex Swindler is looking into this, this might be an issue on 32 bit Windows. In the meantime you can manually copy the plugin files from your OpenStudio installation to your SketchUp plug-in directory, instructions here.
@Alex Swindler @Alex-Swindler is looking into this, this might be an issue on 32 bit Windows. In the meantime you can manually copy the plugin files from your OpenStudio installation to your SketchUp plug-in directory, instructions here.
