I suggest having Output:VariableDictionary in the IDF format so you can copy to your IDF file without error:
Output:VariableDictionary,
IDF, !- Key Field
Unsorted; !- Sort Option
cf https://bigladdersoftware.com/epx/docs/22-1/input-output-reference/input-for-output.html#inputs
what you're looking for is either general:
Output:Variable,*,Baseboard Electric Energy,hourly;
or keyed:
Output:Variable,Zone A BASEBOARD,Baseboard Electric Energy,hourly;
I suggest having Output:VariableDictionary in the IDF format so you can copy from the .RDD to your IDF file without error:
IDF, !- Key Field
or keyed:
