This behavior sounds similar to the issue that I have noticed when moving to OS >3.0. For me the main culprit was that as soon as you add the measure OpenStudio Results the eplusout.sql file becomes unreadable for DVIEW and it just crashes without warning ... you can see this behavior by opening DVIEW directly (not from within OS) and then loading the sql file in the "run" directory. The solution for me here was (and still is) to run the simulation first WITHOUT the OS Results measure, create a copy of the sql file somewhere else like your desktop, before you run the simulation again but this time with the OS Results measure enabled. Hope that works for other folks too ...
