Not sure if this helps anyone still looking for answers why DVIEW doesn't open (or better crashes right away) but I've noticed that as soon as you add the measure "OpenStudio Results" the eplusout.sql file becomes unreadable forDVIEW and it just crashes without warning ... you can see this behavior by opening DVIEW first and then loading the sql file. The workaround here is to run the simulation without the OS Results measure, grab the sql file and copy it somewhere else before you run the simulation again with the OS Results measure.
