Timeout errors can be difficult to diagnose, particularly for international (lots of hops). Assuming you don't get timeouts with other sites, we could try and set up an alternate download location for you to try.
*Update: I have confirmed with a friend in Iran that there are currently issues getting files from GitHub from there; we will post temporary alternative download links tomorrow. As always, thanks to Mostapha (https://unmethours.com/users/8/mostapha-roudsari/)!
*Update: I have confirmed with a friend in Iran that there are currently issues getting files from GitHub from there; we will post temporary alternative download links tomorrow. As always, thanks to Mostapha (https://unmethours.com/users/8/mostapha-roudsari/)!Mostapha!
| 4 | No.4 Revision |
Timeout errors **Update to the Update: The GitHub downloads are actually hosted on Amazon's S3 cloud; this is about as globally accessible as you can be difficult get. We recommend you try again, and if you still get timeout errors, try using a download manager such as JDownloader to diagnose, particularly for international (lots of hops). Assuming you don't get timeouts with other sites, we could try manage the process. A download manager can recover from timeouts, and set up an alternate also can break the download location for you file into smaller chunks, making it more likely to try. succeed. Good luck!
*Update: I have confirmed with a friend in Iran that there are currently issues getting files from GitHub from there; we will post temporary alternative download links tomorrow. As always, thanks to Mostapha!
