Subsurfaces in EnergyPlus and OpenStudio have a subsurface type such as door, window, glass door, overhead door. If you pick window, glass door, or skylight, you need to make sure you also assign a construction appropriate for a transparent surface. With OpenStudio if you use a default construction set, at the building level, it can manage individual surface and subsurface construction assignments.
