I just ran into this same issue. One work around is to use BEopt 2.7, this bug doesn't seem to be present in the older version of BEopt and I was able to model a custom basement wall. You can update the BEopt 2.7 file to 2.8, but when I attempted to add the option to the library, ran into the same error message.
