I have added an issue for this in OpenStudio, https://github.com/NREL/OpenStudio/issues/1657
In the mean time you should be able to manually install the plugin by copying files manually as described here, https://unmethours.com/question/1209/install-openstudio-plugin-for-sketchup-2014-for-windows/
Would you mind replying to this answer with the directory that SketchUp is installed in? This post indicates that you have to install SketchUp on the C: drive, https://unmethours.com/question/4648/sketchup-2015-error-with-openstudio-170-plugin/
