Thanks for pointing out the buttons I needed to focus on - that was helpful. Apparently, what I wasn't comprehending, which Shorowit's response helped me grok, was that a weather file is required from which the analysis times are extracted. Also, for my purpose, the weather file has to have data appropriate to a Clear Sky Model. Attached is an EPW file stripped of all extraneous information and containing ONLY the data used by Energy Plus. Unnecessary values are input as "missing" using the appropriate 999... values. The clear sky model was calculated in a python program using pvlib (https://pypi.org/project/pvlib) from Sandia Natl. Lab. This EPW file is specific to the latitude, longitude and time-zone of Pasco, WA and presumably uses atmospheric turbidity values specific to this location. Note also that temperature and humidity values are set to constant values for the entire year. While these values are totally unrealistic for any practical purpose, my objective is to test Energy+ with the simplest possible boundary conditions.
