The OpenStudio Results Measure expect the EnergyPlus SQL file to be in SI units. This setting impacts both tabular and time series elements. The OpenStudio Results HTML can be either SI or IP. If you want to get the default EnergyPlus generated eplustbl.htm to be IP and you also want to run the OpenStudio Results measure, yes you would have to run the simulation twice.
