Check the Measures Tab. The example OSM has the OpenStudio Results Reporting Measure included, right? Click on the measure and toggle from IP (default) to SI. And you can download/install DView (Darwin) on a Mac.
![]() | 2 | No.2 Revision |
Check the Measures Tab. The example OSM has the OpenStudio Results Reporting Measure included, right? Click on the measure and toggle from IP (default) to SI. However, EnergyPlus results (e.g. .htm) are in SI by default. One can set OutputControl:Table:Style Unit Conversion to "InchPound" directly in the IDF, but not through OpenStudio as far as I know. And you can download/install DView (Darwin) on a Mac.
![]() | 3 | No.3 Revision |
![]() | 4 | No.4 Revision |
Check the Measures Tab. The example OSM has the OpenStudio Results Reporting Measure included, right? Click on the measure and toggle from IP (default) to SI. However, EnergyPlus results (e.g. .htm) are in SI by default. One can set OutputControl:Table:Style Unit Conversion to "InchPound" directly in the IDF, but not through OpenStudio as far as I know. know (EDIT: possible via an EnergyPlus Measure). And you can download/install DView (Darwin) on a Mac.
![]() | 5 | No.5 Revision |
Check the Measures Tab. The example OSM has the OpenStudio Results Reporting Measure included, right? Click on the measure and toggle from IP (default) to SI. However, EnergyPlus results (e.g. .htm) are in SI by default. One can set OutputControl:Table:Style Unit Conversion to "InchPound" directly in the IDF, but not through OpenStudio as far as I know (EDIT: possible via an EnergyPlus Measure). And you can download/install DView (Darwin) on a Mac.Measure).
![]() | 6 | No.6 Revision |
(2022-09-29): Deleted previous link to DView - no longer works.
