Assuming you have found the OpenStudio Application documentation, you may want to start with the measure to make DOE prototype Hospital in your climate zone and for your target standard, and then maybe switch to applying the Create Typical Building measure applied to your custom model geometry. That should get you a running model that you can then customize. Hospitals are one of the more complex building types, so not typically something for beginners, unless you have experience modeling other building types first. You can find the Prototype and Create_Typical measures on the BCL
