I wrote a simple measure called Envelope Material Property Phase Change that could be useful. Note, I did not see significant energy savings using the EnergyPlus example file data. I tried to get manufacturer data from BioPCM, but was unsuccessful.
I wrote a simple measure called Envelope Material Property Phase Change that could be useful. Note, I did not see significant energy savings using the EnergyPlus example file data. data (ref). I tried to get manufacturer data from BioPCM, but was unsuccessful. unsuccessful.
I wrote a simple measure called Envelope Material Property Phase Change that could be useful. Note, I My results did not see show significant energy savings using the EnergyPlus example file data (ref). data. I tried to get manufacturer data from BioPCM, but was unsuccessful.
