If you look at eplusout.err you'll see:
** Severe ** Invalid Output:Variable or Output:Meter Index Key Name =NODE 14
** ~~~ ** For Output:Variable or Output:Meter = SYSTEM NODE TEMPERATURE
** ~~~ ** Entered in EnergyManagementSystem:Sensor=GROUND_HX_INLET_TEMP
** ~~~ ** Unique Key Name not found.
** Fatal ** Errors found in processing Energy Management System input. Preceding condition causes termination.
You have an EMS sensor that is referring to a node that doesn't exist, causing the simulation to fail.
If you don't mean to have an EMS program to set ground loop temperatures (assuming you do not, if it's a PTAC run), then delete the EnergyManagementSystem objects.
