Thank you so much.
It is really helpful and detailed.
Would the below be correct?
Schedule:Compact,
Point_Of_Sale Cooling Setpoint Schedule, !- Name
Temperature, !- Schedule Type Limits Name
Through: 12/31, !- Field 1
For: SummerDesignDay WinterDesignDay, !- Field 2
Until: 24:00,23.88888888888889, !- Field 3
For: Weekdays, !- Field 5
Until: 06:00,29.444444444444443, !- Field 6
Until:10:00,22, !- Field 8
Until:16:00,26.11111, !- Field 10
Until:20:00,29.4444444, !- Field 12
Until: 24:00,29.444444444444443, !- Field 14
For: Saturdays, !- Field 16
Until: 06:00,29.444444444444443, !- Field 17
Until: 22:00,23.88888888888889, !- Field 19
Until: 24:00,29.444444444444443, !- Field 21
For: AllOtherDays, !- Field 23
Until: 08:00,29.444444444444443, !- Field 25
Until: 19:00,23.88888888888889, !- Field 27
Until: 24:00,29.444444444444443; !- Field 29
Thank you so much.
Schedule:Compact,
Thanks
Thank you so much. It is really helpful and detailed. Would the below be correct?
Schedule:Compact,
Until: 24:00,23.88888888888889, 24:00, 23.88888888888889, !- Field 3
Until: 06:00,29.444444444444443, 06:00, 29.444444444444443, !- Field 6
Until:10:00,22, Until:10:00, 22, !- Field 8
Until:16:00,26.11111, Until:16:00, 26.11111, !- Field 10
Until:20:00,29.4444444, Until:20:00, 29.4444444, !- Field 12
Until: 24:00,29.444444444444443, 24:00, 29.444444444444443, !- Field 14
Until: 06:00,29.444444444444443, 06:00, 29.444444444444443, !- Field 17
Until: 22:00,23.88888888888889, 22:00, 23.88888888888889, !- Field 19
Until: 24:00,29.444444444444443, 24:00, 29.444444444444443, !- Field 21
Until: 08:00,29.444444444444443, 08:00, 29.444444444444443, !- Field 25
Until: 19:00,23.88888888888889, 19:00, 23.88888888888889, !- Field 27
Until: 24:00,29.444444444444443; 24:00, 29.444444444444443; !- Field 29
Thanks
| 4 | No.4 Revision |
Schedule:Compact,
Until: 24:00, 23.88888888888889, !- Field 3
Until: 06:00, 29.444444444444443, !- Field 6
Until:10:00, Until: 10:00, 22, !- Field 8
Until:16:00, Until: 16:00, 26.11111, !- Field 10
Until:20:00, Until: 20:00, 29.4444444, !- Field 12
Until: 24:00, 29.444444444444443, !- Field 14
Until: 06:00, 29.444444444444443, !- Field 17
Until: 22:00, 23.88888888888889, !- Field 19
Until: 24:00, 29.444444444444443, !- Field 21
Until: 08:00, 29.444444444444443, !- Field 25
Until: 19:00, 23.88888888888889, !- Field 27
Until: 24:00, 29.444444444444443; !- Field 29
Thanks
