If you look at the Energy+.idd you will find the AirLoopHVAC:ControllerList object. And also find this object in your input file. This object is a list of controllers used in your simulation. For an air loop (AirloopHVAC object) you can have water coil controllers and an outdoor air system controller. There would typically be an outdoor air system (that's 1 controller) and up to 7 more water coils. You should not need more than 7 water coils in an air loop. For that reason, EnergyPlus has limited the number of controllers to 8 per air loop. Your error message seems to indicate that more than 8 controllers are listed in this object. Since this object is not "extensible" (meaning you could expand this list in the IDD and include more than 8 controllers) you can only use up to 8 controllers. Look at your input file and determine why there are more than 8 controllers in this list.
AirLoopHVAC:ControllerList,
\memo List controllers in order of control sequence
A1 , \field Name
\required-field
\type alpha
\reference ControllerLists
A2 , \field Controller 1 Object Type
\required-field
\type choice
\key Controller:WaterCoil
\key Controller:OutdoorAir
A3 , \field Controller 1 Name
\required-field
\type object-list
\object-list AirLoopControllers
A4 , \field Controller 2 Object Type
\type choice
A5 , \field Controller 2 Name
\type object-list
A6 , \field Controller 3 Object Type
\type choice
A7 , \field Controller 3 Name
\type object-list
A8 , \field Controller 4 Object Type
\type choice
A9 , \field Controller 4 Name
\type object-list
A10, \field Controller 5 Object Type
\type choice
A11, \field Controller 5 Name
\type object-list
A12, \field Controller 6 Object Type
\type choice
A13, \field Controller 6 Name
\type object-list
A14, \field Controller 7 Object Type
\type choice
A15, \field Controller 7 Name
\type object-list
A16, \field Controller 8 Object Type
\type choice
A17; \field Controller 8 Name
\type object-list
If you look at the Energy+.idd you will find the AirLoopHVAC:ControllerList object. And also find this object in your input file. This object is a list of controllers used in your simulation. simulation and consists of a list of controller TYPE and NAME pairs. For an air loop (AirloopHVAC object) you can have water coil controllers and an outdoor air system controller. There would typically be an outdoor air system (that's 1 controller) and up to 7 more water coils. You should not need more than 7 water coils in an air loop. For that reason, EnergyPlus has limited the number of controllers to 8 per air loop. Your error message seems to indicate that more than 8 controllers are listed in this object. Since this object is not "extensible" (meaning you could expand this list in the IDD and include more than 8 controllers) you can only use up to 8 controllers. Look at your input file and determine why there are more than 8 controllers in this list.
A1 , \field Name
\required-field
\type alpha
\required-field
\type choice
\required-field
\type object-list
\type choice
\type object-list
\type choice
\type object-list
\type choice
\type object-list
\type choice
\type object-list
\type choice
\type object-list
\type choice
\type object-list
\type choice
\type object-list
