I think I found a bug in our partial fix for large models by increasing stack size. Can you download, unzip, and run the installer at the URL below?
https://github.com/openstudiocoalition/OpenStudioApplication/suites/5379633885/artifacts/169095988
click to hide/show revision 2
No.2 Revision
I think I found a bug in our partial fix for large models by increasing stack size. Can you download, unzip, and run the installer at the URL below?below? The try opening your model in this new build?
If this works for you, it will be included in the next major OpenStudio Application release.
click to hide/show revision 3
No.3 Revision
I think I found a bug in our partial fix for large models by increasing stack size. Can you download, unzip, and run the installer at the URL below? The Then try opening your model in this new build?
click to hide/show revision 4
No.4 Revision
I think I found a bug in our partial fix for large models by increasing stack size. Can you download, unzip, and run the installer at the URL below? Then try opening your model in this new build?
OpenStudio Application 1.3.1 has been released and includes this fix: https://github.com/openstudiocoalition/OpenStudioApplication/releases/tag/v1.3.1
