As placeholders, you could map wind pressure coefficients here (linked to surfaces here), and have an EMS controller adapt exterior surface convection heat transfer coefficients at runtime - a basic setup. The calculations from site wind speed/direction + surface-mapped coefficients ... to local surface velocities would need to be deployed within the EMS controller.
