I encountered this same problem. If you look on the ruby file at line 1320 (as the error states), it is referencing a glare sensor. I did not have a glare sensor in my model at first. When I installed the glare sensor, the model ran just fine.
I am not sure why radiance needs the glare sensor; it may just be the measure is expecting it and did not find it, and therefore throws an error.
