Hi all, today I have the same problem but I have solved it. The sequence of the vertexes should be clockwise in the first surface and counter clockwise in the mirrored surface. If you have a surface with four vertexes 1-4, they are for the mirrowed suface the other way round: e.g
I have changed it manually in the osm file. Maybe there is a more elegant way.
